Trogdor796
- Feb 8, 2012
- Calvin Kubat
I have the following:
Front Speakers: Klipsch RF-62ii
Center : Klipsch RC-62ii
Side Surrounds: Klipsch RB-61ii
Sub: Outlaw Ultra X-12
Receiver: DENON AVR-X1100W
So, I ran Audyssey, but it just didn't seem right. The distances looked good, but it set all the speakers to really low -dB, to the point where I couldn't even hear them unless I set the volume to like maximum. It also set my fronts to large, and all of my speakers had different crossoever settings. There's also a setting somewhere that the options are LFE+Main, LFE, or NONE. I set the fronts to small and set the universal crossover to 80hz and set all the speakers to 0dB. It sounded better that but still seemed...off. I don't know how to put it.
1 - Should I re-run Audyssey? I ran all 8 tests. When I run the tests should I have my chairs moved out of the way and the mic at ear height where the chairs are supposed to be or should I leave the chairs and set the mic on top of them at ear height? Is it necessary to run all 8 position tests?
2 - I've read tons of threads saying floorstanding speakers should be set to small and many others saying set them to large. This system will be used for 50% movies, 40% gaming, and maybe, MAYBE 10% music. With that in mind and my other speakers in the config, what should I set the front speakers size to and what should I do as a crossover for my speakers?
3 - My sub I have at 0 phase, volume dial at half way, and it's crossover dial turned all the way up(120hz I think). It's also set in max extension mode with one of the ports plugged. Does this seem right?
4 - I didn't really check this, but can you change the volume during Audyssey? I'm just trying to figure out why it set all my speakers to like -20dB. could I have had the volume wrong possibly, or is that all automatically done?
5 - The setting I mentioned earlier, LFE+Main, LFE, or NONE, what is that, and what should I have it set to?
This is my first time running Audyssey, and the last time I set up a 5.1 system was a few years ago, so it's a bit different. Just want to make sure I'm doing things right!
