MichaelPR
- Nov 16, 2003
Well finally pulled the trigger on the PB10 today. I would have deffinately gone for somethign bigger but this price point fits my wallet perfectly. And I know that this will be a quality product. I did have a few questions about overall setup and calibration of this model though. I will be placing the sub in a 12x13 room. The room itself does not have straight flat walls. The wall juts out a foot or so to accomodate some built in DVD shelvesand to hide some wiring and pipes. IThe room is located in a basement with concrete flooring that is carpeted. The walls are constructed of either sheetrock on one side and wood covered concrete on two other walls. The rear of the listening position opens into a small dining area that is 8x13. This area has some type of tile applied over the concrete. To the right of the listening position between the right front and right surround is a small opening into a small kitchen. The ceiling itself is a constant 7' 4" throughout this entire area. I was just wondering if there was anything in particular about my setup that I should look out for when setting up the sub. Also I have Avia but is there anything else I should get to make sure that I am getting the flatest bass in my listening area? Thanks for any advice you might have! And also I ordered today Sunday 1/2 any hope of it getting here to NY by Friday?
