I am in the process of upgrading a home theater and could use some help.
In order of priority, my goals are:
1) Simplicity - I am looking to create a low-maintenance system that I can control entirely using my Ipad as a remote over my wifi network. Equipment will all be pretty hidden so I don't want to have to adjust settings/wires and no remotes.
2) Excellent sound and video for 50/50 music/movies
My current setup:
Room:
20'x20'
Inputs:
Mac Mini - Currently used to stream netflix, surf the net, create word docs
Verizon Fios - Cable television/Dvr/fiber optic internet
Receiver:
An older Sony Str-dg720
Output:
Garbage speakers
Epson moviemate projector
All of my connections are via HDMI.
I would like to upgrade:
Speakers: (budget $2000ish)
I tested and liked a pair of Bowers and Wilkins CM1s. (Not really into extra base of CM5).
I would like bookshelf/discreet speakers.
I don't want a 5.1 system (dont like having a center and a base)
I would consider a 4.0 system if that would sound good, but I don't want to lose anything from recordings. If center's sound can be distributed to fronts, then 4.0 is ok.
Receiver: (budget $1000)
I like that Denon and Marantz can be controlled using an Ipad App.
I've read that they go well with the CM1s.
I would like to have either Airplay or Apple Tv to stream music from my Ipad to my speakers.
Projector: (budget $1,500)
I heard good reviews about Epson Powerlite 8350.
Questions:
1) Any suggested improvements on Speakers?
2) Any good, Ipad controllable, reciever recommendations for my setup?
3) Any particular Denon/Marantz model?
4) Should I go with stereo 2.0 or 4.0? If 2.0, what receiver/amp?
5) Should I even upgrade my receiver or will my old Sony Str-dg720 be able to drive the speakers as well as newer recievers?
6) I like Audyssey's ability to calibrate/equalize sound. Do other receivers do this as well without audyssey, i.e. yamaha/pioneer?
7) Any other projector recommendations?
8) Any other major improvements that you would suggest?
Feel free to answer any of these questions...
Thanks.
My current setup:
Room:
20'x20'
Inputs:
Receiver:
Output:
Garbage speakers
Questions:
Thanks.
