I just finished wiring my family room for 5.1 surround sound and I am looking at starting to choose speakers and a receiver. The room is rectangular at 14x15 ft with 9ft, flat ceiling. As this is our family room, my wife is very adamant about it not turning into a home theater with an obnoxiously loud sound system. Furthermore, she wants to keep the speakers as compact as possible and keeps envisioning something like those Bose satellite speakers.
I am thinking about just starting off just a 2.1 or 3.1 set up, with the option to add center and/or rear channels down the road. The front channel speakers will be sitting atop a built-in that runs along the wall that the TV is mounted on, while the rear channels will be mounted on the wall directly behind the couch. I wired it so that the receiver will be tucked away in one corner while the sub can sit in the opposite corner.
The ultimate question is... can you recommend compact size (smallest possible?) speakers and a subwoofer that do not drastically sacrifice sound for size? Great if you can recommend a 5.1 set, however, I am fine pairing speakers and building the set over time. Also, this may be suited for another board but any recommendations for an amp/receiver?
edit: I should add; my budget right now is for <$1,000. If there aren't any good 5.1 + receiver set ups that are decent at the price (which wouldn't suprise me) I am okay starting with just stereo, 2.1 or 3.1 set up for now any adding on done the road.
