Manjaro
- Mar 24, 2021
- Joshua
So I have had the same home theatre system for years now and wanted to upgrade. I have a 5.1 channel Klipsch system that still sounds great for me and an old Yamaha AVR. I just upgraded the Yamaha to the RX-V385BL for the 4k passthrough. I didn't know what ARC was until 2 days ago and my tv has the HDMI port for it, unfortunately my old avr didn't so I was forced to use fiber optical toslink cable anyway, which I have been using for years now..... I now understand that I don't need to use the optical cable with ARC but upon realizing this, I realized also that my AVR doesnt have ARC input so I got a new AVR yesterday, The RX-V385BL and I already had a new TV on the way. Also I have an xbox one x that I use for 4k video and gaming that I want to keep with the best picture and audio quality I can get. Do I use the AVR as the switch and plug the xbox into the AVR and use the eARC on the new tv to connect the AVR to the tv? Or do I plug the xbox into the tv and then the tv into the AVR using the eARC.
So I wanted some advice on how to properly set up this system to get the best out of it I can. Like What do I need to plug into what piece of equipment for ease of use and best setup
My new setup is:
TV- Vizio P65Q9-H1
AVR- Yamaha P65Q9-H1
Xbox one X
Klipsch 5.1 surround sound system
Oh and I got 2 ocean 48 audioquest HDMI cables that are eARC level 1 and can transfer 8k and 10k so I knew I would be covered with those 2 cables.
So for recap, I have TV AVR and xbox that I want to connect and be able to have everything coming out of the surround sound
Oh and PS I do want the tv apps like Netflix and prime to come out of the surround sound too when not using the xbox but just the tv apps.
Thanks for any help and input.
My new setup is:
TV- Vizio P65Q9-H1
Xbox one X
