Trogdor796
- Feb 8, 2012
- Calvin Kubat
I have a Sony HW40ES and Carada 110" screen that I would like to set up next week. Problem is, I don't have my actual theater seating yet. I ended up buying a whole new set of speakers, sub-woofer, and receiver on black Friday, so I will be using some chairs we already have until early next year when I am able to buy some actual theater seating.
I've been told that the height drop tube you buy depends on how many rows of seating you have, how far back they are, and what height they are at. Since I will be using some temporary seating for a bit, I don't want to order a drop tube that will not work with whatever actual seating I end up getting. All I know for sure is that I plan on doing two rows once I have actual seating. For now, we will probably just have some normal chairs in there.
I got a Chief RPA 020 mount with it. So I have the projector and that mount, no other mounting hardware. For now, is it possible to use that mount and just put the projector flush with the ceiling, and then add a drop down tube later? Is there an adjustable drop down tube that I could buy? If those are not options, I do have an old wood entertainment center that is 6'3" high, that I could just put behind my seating and set the projector on top of. Given my room dimensions and the projector and screen I have, would that be possible for now, using lens shift on the projector?
Just trying to figure out the best temporary option here.
