Powering Bass Shakers (1 Viewer)
Michael Gdwn
How would I power 2 bass shakers with a bass plate amp? And does anyone know of a cheaper way to power 2 50 watt bass shakers that buying the Partsexpress.com 120 watt plate amp? Thanks
Michael
David.N
I use the parts express bass plate amp for mine. Works great, very easy to set-up. Get lots of compliments! :emoji_thumbsup:
Mike Gl
I purchased a used receiver on Ebay to power my bass shakers. The cost was less than $40 and I avoided shipping costs by purchasing one within driving distance. The receiver was rated at 55 watts per channel and had a rumble filter that rolled off frequencies below 20 hz. It worked fine for this application.
Mike
foster2292
