This is going to be my first HT build. I have a basement that I am going to make into a HT. I need some advice on where to put the screen. I was going to put it on the wall that is at the top of the sketch. The door that would be next to the screen if I put it there will go to the media room. It is all concrete but framed with 2x4's right now; 9' ceilings. Then someone suggested I put it on the long wall opposite the stairs but I think that would not leave much room for seating. I know just about nothing in regards to laying out a HT and what works well. I'm just looking for some first hand experience.
