Pioneer Elite RPTV and HTPC (1 Viewer)
WilliamC
Hi,
Can the VGA in on the TV be hooked up to an HTPC? I ask because the manual says that it shouldn't. Otherwise I believe this set has a set of BNC inputs so would a vga/BNC cable work as well as the VGA?
Thanks in advance,
William
John Parris
I don't see why not... maybe it's assuming you dont have your video card set to a 16x9 output? Use powerstrip and it should work...
Blogger1597
