RaulR
- Sep 11, 2002
I just got a Philips 34PW9817. In the manual, it said to connect DVD players with progressive scan output to the AV4 (wideband) input jacks using component video connectors. This is what I did in the initial setup.
Anamorphic images look great on the TV, but non-anamorphic ones are horizontally stretched. I can't adjust the TV's display format, because there's only one display option with the wideband input: widescreen. I tried turning on the Auto Progressive setting on my Pioneer DV-45A to see if this would fix the problem, but instead another problem occurred: the menus on some DVD-A and DVD-V discs got messed up (nothing but colored streaks).
Am I right in suspecting that the cause of the problem is these wideband input jacks, and that all I have to do is to connect to the other component-video jacks (AV3)? Or is it something else?
