helm
- Nov 17, 2010
- Bill
Hi, I am in need for some advice here with my new Yamaha RX-V2065 AV Receiver. I thought I was making progress in working out the functions of this Receiver but I have come unstuck again and can not work out what to do. I seemed to have all the functions working playing DVD Blu-Ray Audio CD and audio from USB stick and all was working fine when I last turned the machine off, but now I can not get any Audio from either my DVD Recorder CD or Blu Ray player only sound I get is when I switch on the Tuner no problem there at all. I am fairly certain that it is most likely just a setting that need changing, all connections are HDMI and movies are playing ok just silent. When playing CD’s the tracks are displayed on the TV screen and are playing but no sound. On the Screen of the Receiver when sound is available the selected speaker setup is indicated for example 2 channel Stereo or 5 channel surround, but now it is not showing it will indicate PCM but that is it. Anyone knowing how to get the ball rolling again, I would be very grateful. As you can see I am no expert with this new toy.
