hawkeye12345
Grip
- Dec 29, 2008
- Dennis
First off, thanks for all of the help to this point. I really appreciate the input that this forum provides.
I have decided on the following components for my initial 5.1 system:
Pioneer 50" Plasma
Center - Axiom VP150
front(s) - Axiom M22 v2
Side Surround - QS8
Sub - SVS SB12-Plus - I don't think this is set in stone yet but it seems to be a great price for a great sub.
Denon 4806 receiver
PS3 for gaming, blu ray and media downloads
Oppo HD DVD player
The viewing couch will be placed 8' from the TV screen and approx. 12' from the rear wall. The room itself is 20' long. I point this out because the question is in regards to the rear surround speaker location as I think the rear wall is much too far from the viewing area to place the rear speakers.
My question is this:
I will pre-wire for a 7.1 surround but initially will forgo that and utilize the 5.1. The rear surrounds will be ceiling mounted and the ceiling is pitched at about 33 degrees on both sides, kind of like the inside of a tent.
What speakers do you recommend that will blend well with my system? Will in-ceiling be ok for this setting or should I just skip the 7.1?
Pioneer 50" Plasma
Side Surround - QS8
Denon 4806 receiver
Oppo HD DVD player
