StarFyre
- Jun 25, 2009
- Sanjay
Hello all,
From another thread (long story) we're going to be having some work done in our theater area. We've decided to go the more work route which means, opening up the ceiling a bit is going to happen (to add a conduit, and help correct a wire that's too short).
Since the work is going to happen anyways, this is a good time to wire up some atmos speakers. My question is about which to get. i was looking at these, the aperion height modules for the front 2 speakers (and maybe the rear), put into the ceiling and aimed at the seating area:
https://cdn.shopify.com/s/files/1/0...00x1000_v2_4000x.progressive.png?v=1669357736
(our setup uses aperion already so figured might as well get the same brand)
OR , since im in canada, these are cheaper and easier to get: https://www.paradigm.com/en/in-ceiling-speakers/ci-home-h55-r-v2
Those are just the ceiling speakers ppl place into the ceiling cavity so not directional from what i can tell.
Does anyone use these type of ceiling speakers for atmos or do the front and rear atmos speakers need to be directional?
regards
SF
regards
SF
