Carlo_M
- Oct 31, 1997
For this Cyber Monday, I figured I'd already invested heavily in a 5.1.2 Atmos signal chain (front heights + traditional 5.1 setup). I never added rear heights because back when I moved into this apartment it was a pain in the butt running rear wires under the carpet (I had this special tool to do it which was like a plumber's snake but for wire). I remember it being such a hassle and effort I never wanted to do that again. Since the front heights were on the same side as the receiver, running wires to them was easy. I've read more than a few testimonials saying adding the rear heights would improve overhead Atmos sounds significantly (including some testimonials saying if you couldn't do FH+RH it almost wasn't worth just doing FH).
Well with SVS's Cyber Monday sale, I saw that they had Elevation Prime in white on the Outlet Store, listed as No Damage, Full Warranty (which I assume means it was a customer return with no visible damage)...in fact I might have gotten the only pair as it's no longer listed...and also purchased the SoundPath TriBand wireless adapter. Since I live in a wifi-congested area I figured I'd rather be safe than sorry with regards to robust signal transmission. The transmitter and receiver will have unbroken line of sight and be about 15' apart. Fortunately I'm such a hoarder I have a couple of slightly older Pioneer Elite AVRs sitting around that can power the rear Atmos height speakers. Given how limited frequency the rear height speakers get in Atmos I'm not concerned about the power mismatch, especially after I run the calibration tool again to dial in the latency and levels.
One thing I am going to have to try and figure out is how to trigger that receiver to turn on when I have the main AVR turn on. If I can't accomplish that wirelessly/automatically I'll just have to remember to manually do it when I have an Atmos program running.
Looking forward to seeing if the hype of full .4 overheads really does improve the immersion of Atmos. I'm a huge sucker for MCU, Sci-fi, Fantasy and Action movies so I have no shortage of aggressive Atmos mixes I can use to put it through its paces.
Anyone else using SVS's SoundPath wireless transmitter? Any testimonials, or suggestions/advice you'd care to share with a first time owner? Thanks in advance!
