EricDeB
- May 30, 2004
Hey I have a sharp flatscreen 27 inch tv, and I would like to use the composite input in the front permanently. I don't like the cable sticking out of the front, and I was wondering if it would be possible to take off the flat panel frame and run the cable just inside the frame so that it sticks out the side. Is this possible? Is it easy to take off the front panel frame? I only want to use the composite input, not the audio connectors.
Thanks a ton
Eric
Thanks a ton
Eric
