pauld.nz
Grip
- Feb 2, 2004
Hi i have a pair of great sounding floor standing Jensons but carnt find any specs on them. Model number is DR-1205. I have searched google many times and nothing seams to come up.
Does anyone have the specs or no where i could find them for the Jensons ?
I would love to have the specs , because all i know at the moment is that they r 8 ohm 130W RMS (max) speakers.
Question: I am running the Jensons at the front and 2 small 40W RMS aiwa's at the rear through a pioneer 110x5 prologic amp. The amp dosnt have settings for speaker size or distance between them. I have a brand new sony active 12" subwoofer (150watt) conbnected to the sub out in the amp. My question is, why carnt i here the sub over the Jensons. When i dissconnect them it sounds great (with the little aiwas) but the Jensons just seam to run it down.
What are my options ? I was told that you shouldnt turn the sub volume over half (in case of clipping) and i have played around with the frequencys.
I am getting a new amp soon (Kenwood 6.1 with DTS2 110x6) which has heps of settings including level controls for the sub. I want most of the bass to go through the sub taking the strain of the jensons.
If i adjust the speaker size, distance and levels for the speakers and up the levels for the sub with this new amp, will that make that much difference to the overall sound ?
I havnt tested it out yet for home theater. I wouldnt have bought it if it didnt sound so good in the shop. It got really good reveiws on the net too.
