Drmrforman
- Jul 21, 2012
- Mary
Will shortly be maintaining a 2nd location in a smallish apartment. I want to buy adequate but not overwhelming equipment and at the component level I'm looking at I don't find price to be the issue. The issue is trying to ascertain if the parts will work together well. I have decided on a Sony Bravia KDL 46X850 TV and am considering either the Sony BDP-S760 or OPPO BDP-93. If I get a receiver, I am thinking of the Marantz 1603. I plan to "settle" for a soundbar for this space and they all look unexceptionally different so far.
So these questions occur to me:
1) Do I even need an A/V receiver? Or will this setup perform well enough with just TV/BDP/sound bar?
2) It appears that CC will not be available on cable TV channels using HDMI connections. What are the workarounds using non-HDMI connections?
3) To my unsophisticated eye, it appears that some of the higher end soundbars may make an A/V receiver unnecessary. Am I correct? Can you recommend any of that nature?
4) I will really need remote headsets if I can't get CC; it's a small apartment and I want to be a good neighbor! Should I be satIsfied with optical or older hookups, or are there some using HDMI connection?
5) Is anyone aware of incompatibilites between the items I'm considering? Or do you have other recommendations in similar areas that you know work?
6) Please recommend some sites which will show me details about how to string wires/cables between components.
