Parts needed:
1 spare speaker
1 spare receiver
1 interconnect
speaker wire
That's it.
To "assemble" it: A/V receiver's subwoofer output ---> unused input on the secondary receiver (not a phono input!) ---> secondary receiver speaker output ---> speaker.
* Sub's gain is adjusted with the secondary receiver's volume control.
* Polarity - 0 or 180 degrees - can be changed by simply reversing the speaker wire at the speaker's input (or secondary receiver's output if that's easier).
* crossover point is adjusted within the A/V receiver.
You're done.
I've been experimenting with my own sub system - see pics below - for more than a year now, made up of my Pioneer SX-6 receiver I bought new in 1983 and a Realistic Nova-8 bookshelf speaker, which uses an oddball-sized eleven inch woofer w/cast aluminum frame in an acoustic suspension enclosure. I bought the Nova, which had no mate, for $5 at a thrift store. Its woofer uses a doped cloth surround and is still fully compliant and the woofer works perfectly. Until they turned into a cell phone and battery store, Rad Shak actually made a lot of decent audio gear until the mid 90s.
Obviously the overall quality of this system will be determined by the speaker used and the power output capability of the receiver. As far as size of the subwoofer is concerned, for most rooms personally I think a speaker with a 10" woofer is the minimum. Dorm rooms (if the R.A. doesn't care) and other typically very small spaces can get away with an 8" woofer.
Volume-level wise, probably the biggest factor that will keep most of these cobbled together subs from competing with normal subs is amplifier power. But watching the SX-6's power meter, while admittedly not ultra accurate, I saw that most of the time in my little 11ftX14ft mancave, it hovered around 5 to 20 watts at normal listening levels i.e. I can still talk to a nearby person without shouting. But if I tried to turn it up to a level that did require shouting, the power output VERY quickly shot up to the 60 watt level but that was after the Nova's woofer cone started noisely banging against its frame.
>>> As far as how my own sub system sounds, I think it sounds just like a "real" sub, probably one going for around $250 in a brick & mortar store but need to clarify that: the sound itself is more on par with a $400 sub, but ultimate volume level is more like a $150 sub - that Nova just wasn't designed for the combined bass output of up to six separate channels of a modern movie's soundtrack!
Another option: you could use TWO speakers for your sub system (plus, supposedly two subs can create a bass soundfield that covers the room with fewer gaps). And if your receiver has a mono button that affects all inputs and not just the FM tuner, there is a good chance you won't even need a splitter to convert the sub output to 2 channels (for input purposes), because usually, pushing the mono button will internally direct that single signal to both channels of the receiver.
Besides just being fun to mess around with, part of the motivation for writing this is the increasingly lousy state of our economy: for example if you have to make a mortgage payment, that can really put a dent in your A/V budget; and if youre a college student you know the frightening cost of tuition/books/etc is making it extremely difficult to afford much else, much less frivolous items like audio gear.
Now you can apply that earth-friendly attitude you keep hearing about to your A/V hobby and recycle that old gear taking up space & irritating your wife/girlfriend/parents!
1 spare speaker
1 spare receiver
1 interconnect
speaker wire
That's it.
You're done.
