Home Theatre Upgrade Help (1 Viewer)
kiwipip
Philip
Hi all I am new to this forum, but have been an avid Home Theatre follower from way back to the 3 Gun Projectors era.
My room dimensions are W190" x L 221" x H95" one row of Theatre seats
I have recently gone from a 1080P 100" when I had upgraded to a 4K Projector I updated to a 120" 16:9 but since then I upgraded my projector again this time to a JVC NX9 (8K upscale) so this has set off another chain reaction.
My plans are now to change my Speaker and screen configuration to
140" 2.35:1 Acoustically Transparent Screen
Front Speaker Wall KRIX MX-20 set up for behind the front screen
Krix Symmetric Speakers to Surrounds and rear
My problem is where do I place my rear surrounds as I have a double entrance door to the rear of the theatre. (I was thinking of filleting the corner at 45Deg and place the rear at an angle facing the sweet spot) Currently the rears are Speakercraft AIM LCR 5 Kevlar that are incorporated into the pelmet angled towards the main seating area.
Any thoughts HELP
John Sparks
Menifee, CA
John Sparks
Welcome! Just the increase of the screen size and a top of the line projector are winners. Everything else will be icing on the cake.
That'll be a tough one on placement of the rear surrounds. Maybe in from the side walls on the back wall below your mini-split and above your sub..
Gigaspin88
