Al Garay
- Oct 23, 2002
I turned on the power and nothing... there is no sound coming from my new subwoofer.
Here are the details... this is a used Hypex HS200 and a new 12" Soniccraft SCC300 driver that I bought from reliable sources... so I expect are functional. I'm connecting the subwoofer to my 2-channel stereo consisting of:
* BentAudio TX102 pre-amp
* AKSA 100W mono-blocks
* Ellis 1801 satellites
I bought a 12' subwoofer cable and y-adapter from RS. I have the Y-adapter connected to the R-channel output from my pre-amp. One leg goes to the IC to my amplifier. The other leg goes to the subwoofer input.
I'm going to try to use the high-pass crossover, connecting directly from pre-amp to sub-in and sub-out to my satellite amps. Is this correct?
What are the high-power in connectors? They look like speaker binding posts.
I wish I had the manual. I appreciate the advice.
Al
Al
