HDTV Hookup question? (1 Viewer)
Scott Goldsmith
Hey guys, with the new house I got a Cox cable HDTV setup, got the Motorola HDTV box, they gave me component cables with it, but it has the option on the back for DVI or 1394 connections. What do you all recommend I use to hook up to my Mistubishi WS-65869? I am 99% sure my TV has a DVI connection on the back of it, any better picture quality with it over component? I would like to FINALLY use my 1080i for something, never used it yet [:frowning:(]
Thanks for the help!
Robert_J
Mississippi
Start with component cables connectd to the YPrPb/GRBHV connection. You will probably have to go into the TV's menu to turn off the HV.
I'm not familiar with the 1394 connections since my 55411 only does component.
-Robert
Nielmb
