ceejaynj
- Nov 30, 2010
- Charles
A simple question...I have an hdtv, hd stb, Sony 5.1 amp, up-convert dvd player, VCR, and Infinity speakers (5 with no sw) as my equipment. I am in the process of making all the connections for my first true ht.
On my prior "system" (before I got my hdtv and Sony amp) , I had all my equipment connected to my non-hdtv, then connected the non-hdtv to my bookshelf stereo (video channel). This worked fine for me, since I don't use surround all the time.
In my Sony amp manual, it mentions that I can connect my equipment a few ways. I can connect my equipment to my hdtv, then connect my hdtv to my amp and apply amp effects to the audio from the tv...basically how I had it with my prior "system".
However, it also says I can connect all my equipment directly to the amp. What are the advantages and/or disadvantages of either type of equipment connection?
Many thanks!
Many thanks!
