Front Projection (1 Viewer)
CurtJ
Hi Guys, In the home that I am building I would like to have a home theater/ sports room. I plan on watching movies, watching football and having a video game system. Will a front projection be ok for this situation?
Chip_Slattery
Front projection would be fine. If you're still in the planning stages try to build into the design as much light control for that room as possible, since ambient light is the bane of front projection.
(if it's a basement room you're probably all set on this)
If it's going to be a dedicated room for the purposes you mentioned I would consider no windows at all...otherwise budget for appropriate light blocking window treatments as they can get pricey.
papill6n
