Rob Ritch
- Jun 5, 2002
All,
I have a question about the AR072 digital coax cable. I hve just re-arranged my HT and it required me to replace the 3' coax cable that I was using for the DVD player. The original cable was a monster, but when I replaced it I went with the AR Performance series to match all of the other interconnects in the system.
Now to the question, the Monster cable had an arrow indicating the direction that the signal should travel, i.e which end should connect to the receiver. The new AR does not have such an indicator. Does it matter which end of the cable connects to the receiver, if so is there a way with the AR to tell which end should be connected to the receiver and which end should be connected to the DVD player?
Thnaks for the information
