EricDeB
- May 30, 2004
Ok so I have:
Sharp 27 inch tv 27F543
Paradigm Center 170
Ikea magiker stand http://maplewoodonline.com/classifie...E093588_S4.jpg
My first question is, where do you guys think I should put my center speaker, either on top of my tv or try to find a small shelf and put it between the ikea stand and the tv. If I did the second option, the speaker would not have to be angled and I might be able to find a shelf that would enable my tv to swivle.
Secondly, what type of tv shelf would you guys recommend for putting the center on top of the tv, or possibly between? It would probably have to be able to angle the speaker down if it was on top.
Thanks a ton
Eric
Paradigm Center 170
Thanks a ton
Eric
