DonRo
Grip
- Dec 7, 2003
Based upon extensive research here on this board and diverse test reports, I have purchased the Denon DVD-2200 and AVR-1804.
The DVD player arrived yesterday and I assume the AV receiver will arrive within the next couple of days. I read through the DVD’s user manual last evening and I realized they show a number of different ways to connect the DVD to the TV (both directly and via the AVR), but without significant clarification. Note: I plan on purchasing a projector for my home theatre solution... but that will have to wait a while after making this current investment.
My TV is a Sony KV-29FX66 (this may be an European only version, as far as I can tell? I am currently located in Germany) It is just under 1 year old (still in their product line) and is a WEGA 100 Hz 4:3 format (fully supports 16:9 mode though) and has 3 SCART inputs on the back (labeled SAT, DVD, VCR) and 1 S-video input on the front panel.
Nothing in the user manual or on the Sony web site indicates what these inputs really do/are, and as a "newbie" to this whole home theatre situation... I am at a loss to how best to connect my components now.
It is clear (I hope?) that I should connect the audio via the AVR-1804 to the Canton Movie CD1 surround-sound speaker set I also just purchased... but should I connect the video to the TV directly or also via the AVR-1804?
Regardless of directly or via the AVR-1804... does anyone know if I should use the component out, for example from DVD-2200 to the SCART (DVD) input on the Sony TV... or would it be better to use the S-video connection?
I will need to buy the necessary cables and understandably would like to do so before all the new gear arrives. I sincerely appreciate ...and would like to thank anyone who can help me out here.
All the best...
Don
All the best...
Don
