Well, I thought I had it all figured out but now I'm not so sure. I have about $1300 or so to play with. I am all setup with 7.1 surround in my HT (Polk in-walls - yes, yes, I know, not the way many of you would go, but I have to live with my wife, you don't ). My older Onkyo receiver is dying and I want to shore it up with 7 channels of amps. I will eventually get a pre/pro (latest Marantz or Yamaha, most likely) to replace the Onkyo - just can't do both now.
I nearly pressed the "complete order" button for an Emotiva XPA-7. It would do everything all in one nice "little" box. But do I really NEED it? Would an XPA-3 at half the price + a couple of smaller, cheaper 2 channel amps (like a pair of Onkyo M-282's or some-such) to power the surrounds be a better technical solution? It's certainly a bit cheaper of an option, but not by much unless I skip retail (about $250/each) and buy online (as low as $150 each)
What to do... What to do... I've got a hole in my pocket and a little money to burn... Thoughts?
