Adam
- Nov 3, 1998
I think I am finally going to build a subwoofer. I am going with a tcsounds 15" driver. What is the easiiest configuration to work with, dual 4 Ohm voice coils or single 4 ohm voice coil? I would guess If I were using a plate amp I should use the single and If I am using a stereo amp I should go with a DVC? I will only be using a single driver. Can an inexpensive pro amp drive a single 4 ohm load if you run it bridged?
Also, can I get some suggestions for an amp to run a TC Sounds TC-2000 15".
Adam.
Adam.
