Robert_J
If your studs are 16" on center, then the box needs to be 17.5" wide. I'd also go with dual layer MDF. For my dual 18" manifold, it is 17.5"x24"x24". My cut list for dual manifolds was:
8 pieces - 24" x 24" (sides where the drivers mount)
8 pieces - 24" x 14.5" (ends)
4 pieces - 21" x 14.5" (top)
For you, I'd go with:
4 pieces - 24" x 48" (sides where the drivers mount)
4 pieces - 24" x 14.5" (ends)
1 piece - 22.5" x 14.5" (window brace for the middle)
2 pieces - 45" x 14.5" (top)
You will drive each pair of 18's with one channel of the EP-2500. Each pair of drivers wired in series for a 4 ohm load.
I never asked. Do you have a separate room for your EP-2500? If not, you want to investigate making the fan quieter.
-Robert
-Robert
