Rob Gillespie
- Aug 17, 1998
The audio setup menu allows you to stipulate whether a subwoofer is used or not and has large/small settings for the other speakers. It would stand to reason that if the sub was set to NO, then the LFE signal would be fed through to the main speakers - just like any other 5.1 processor would do.
However with this configuration, the LFE signal is gone completely. I'm getting none of the LFE signal coming through the analogue outputs at all.
I had to sell my sub a few months ago as I now live in a flat. What this basically means is that I cannot use the analogue audio connects from the DVD-2900, relying instead on the digital connection to my Denon AVC-A1 amp. The AVC-A1 is quite happy to downmix LFE but obviously the 2900's analogue audio sounds better.
Anyone managed to get this working or is it just another addition to my list of 2900 disappointments?
