Dennis Nicholls
My 2008 Maytag washer developed a problem: sometimes the cold water rinse cycle used full hot water by mistake.
I did some thinking and guessed that the problem was in either the 4 position temperature switch or the water inlet (solenoid) valve. It was most likely the switch so I ordered a replacement. New ones are backordered everywhere but I found a seller on eBay that had "open box" specials. It actually arrived new in a factory sealed bag, although the bag itself was shopworn. Kudos to him.
It was an easy part to swap out. Now my hot cycles have hot water, warm cycles have warm water, and all rinses are cold water.
When I opened up the control panel on top of the washer, I discovered a folded up paper copy of the washer's schematic. Why the heck is that hidden inside the washer? Why not with the owner's manual and other paperwork upon delivery?
I recall this happening with other appliances too.
