Bill Barrington
- Jan 18, 1999
I'm planning on buying an HDTV within the next 6 months. I would like it to be 51-65" and widescreen. Ideally I would like to get out for under 3K. I'm just starting to research different models and was wondering if anyone had any preferences? What should I look for as far as outputs go? And what other things should I be looking for?
Where are some good places to look online? If I can't get it online I will end up at Best Buy probably since that's the only place that sells them near me.
Thanks for any help you can provide.
