David Susilo
- May 8, 1999
Well, the title says it all.
THanX beforehand.
THanX beforehand.
Don't ignore this! In a properly wired home filled with appliances in good working condition, you shouldn't be
receiving ANY kind of electric shocks.
Not to mention that a properly wired house shouldn't be causing ground loops. You obviously have voltage floating between neutral and ground which should be the same potential. I'd get this fixed ASAP.
Link Removed | Burt Lancaster is Link Removed | dOc
