Chris PC
- May 12, 2001
Just asking for input from those who are aware of particular receivers and/or Pre-Pros that have either:
1) Selectable bass management, such as the Outlaw, with 60, 80, 100, 120 and so on, or the Denon 3802 with 80, 100 etc. I have heard Sony has some, I'll check it out.
2) A fixed 80 hz xover. For instance, the Yamaha has 90hz, which is close, but the Integra's have 80hz, as do others.
3) Looking for DPL II and 6.1
4) If its a receiver, at least 80-100 watts per channel. Prefer 100 wpc.
Any suggestions? I could also do something like, use an SR 5200 with an MM9000 amplifier and OUTLAW ICBM, but it would be over my budget.
I may go ahead with a Marantz SR 6200, but before I do, I would like to compare. I'm off to research.
