Derek B
- Feb 11, 2001
I want to connect two receivers to the same input port on my receiver. What is the best way to do this? Pro's and Con's?
--Derek
--Derek
Geez, how many receivers do you need?I know what you meant since I read the subject. Anyway, there are three primary ways to split an RCA input into two. They are as follows:
1) Monster Turbine Y-adapters: These are gold-plated RCA input connectors that plug into your receiver (sold as a pair). Each connector has two RCA inputs at right angles to one another. Audio Advisor sells a pair of these adapters for $20. Here is the link:
http://www.audioadvisor.com/store/pr...A%20Y-Adapters
I use these with a stereo amp and they work well. The drawback of these Y-adapters is that they are bulky. As a result, I have to use inputs on the end of the bank of inputs on my amp. They won't fit into inputs that are sandwiched between two other sets of inputs on the back panel when you have cables all over the place. Other than that, they work well.
2) "Standard" Y-adapters: Monster, Radio Shack, and many other companies make this type. Basically, you have a short cable that has an RCA input on one end that plugs into the receiver and is split into two inputs at the other end. These are sold in pairs as well (left and right inputs). I'm not sure how much the Monster version of these splitters sells for, but Radio Shack's version are pretty cheap. You should be able to find the Monster type at Circuit City, Tweeter, Best Buy, Good Guys, etc. In addition, you might be able to find the RCA brand at Wal-Mart. Some people say that these types of Y-adapters lead to signal loss and that the aforementioned turbine type are better. I haven't used the cable type, so I can't comment. You shouldn't have problems fitting the cable type into any location on the back panel of your receiver since the split inputs are spread out by the length of the cable.
3) Radio Shack "Piggy-Back" Cables: Radio Shack sells RCA cables (as a pair) in which the RCA connector that plugs into the receiver has an RCA input on it. Basically, the RCA input is right behind the RCA connector pin. I used these briefly, but I didn't like the construction of these cables, so I went with the Monster Turbine Y-adapters instead. I'm not saying the Radio Shack cables are bad. I just switched out of personal preference.
Some audiophiles say that splitting inputs with any of these devices leads to signal loss. I have not found that to be the case with the Monster Turbine Y-adapters. That said, if you do use any of these splitting devices, it is often considered a good idea to only have one of the input components on at a time. Some people feel that having the components on together degrades the sound of the one being used. I haven't tried running both components at the same time in my system, so I can't speak from firsthand experience here. In any event, I would say that you should be able to use an RCA splitter with good results.
My:
HT Pics ; Equipment List ; DVD Collection ; LD Collection
KeithH: Saving the Home Theater World Before Bedtime
