AaronNWilson
- Jan 28, 2001
What are the costs of filming in 70mm in comparison to 35mm?
Short answer: astronomical.Really? I'm not trying to be difficult, but I would have guessed that the vast majority of the cost of making a film goes to salaries, sets, special effects, and the like. I can see how shooting in 70mm versus 35mm would be much more expensive, but I'm having some trouble getting my mind around the possibility that it could make or break a budget.
but I'm having some trouble getting my mind around the possibility that it could make or break a budget.Of course it can. Enough Turkey Jerky can... Seriously, these are real issues, it all adds up. Btw, you should always take a 'stars' salary out of any production budget considerations, as that is an entirely different beast, and may be why you have whatever budget you have to even make a film...
Cam depts on major films often have to plead their case for a few days rental of a particular lens... Prod companies won't fly all your guys out to save bucks, they will hire a local for less... It's all about money...
On a feature film, besides the cost of stock and processing and prints (and remember that you will use much more stock, just as you use much more 35mm than 16mm for the same run time - see below), Shooting 65mm will almost certainly increase salaries. In fact, it will likely increase crew size. Setups will take longer, thus more days to film, thus more salary cost. There are more mag changes, and more waste.. Again, time and money...
Mag run times:
400' 16mm mag - 11 min 07 sec
400' 35mm mag - 4 min 27 sec
500' 65mm mag - 4 min 27 sec
1000' 16mm - 27 min 46 sec
1000' 35mm - 11 min 6 sec
1000' 65mm - 8 min 53 sec
Major corrections 07/09. Apologies.
Anyway, there are many reasons why 65 isn't used much. I can't fathom a situation where I would be interested in it... But Roberto, budget is probably the number one reason you would hear from any filmmaker/producer.
are the camera rigs for 65mm significantly larger than those for 35mm?Not to speak for Scott, but the new and updated 65 MM cameras and lenses that were used for "Far And Away" and "Hamlet" are not that much larger than 35 MM units. Century Plaza in Los Angeles had one of those cameras on display in their lobby, when they were showing "Far And Away" in 70 MM. And yes, shooting in 65 MM does require an added expense on lighting etc. but in my opinion it is worth every penny spend.
Nowadays Studios would rather pay astronomical salaries to stars (25 Million plus )than to spend a little extra to shoot the film in 65 MM. Any of you who saw either "Far And Away" or Hamlet in 70 MM must have noticed how breathtaking the picture looked on the big screen. And those who marvel how DLP looks have not experienced true 70 MM before. The following films would have specially looked great, had they been shot in 65 MM.
Braveheart
Titanic
Dances With Wolves
Lord Of The Rings
Heck, if you want the ultimate, The showscan process used 65 MM photography and projection at 60 Frames per second.Personally, the thought of higher frame rates for narrative/dramatic filmmaking turns my stomach... Part of what 'film' means to us regarding movies, what defines it's look and effect, and even separates it from video, is the frame rate... Is that 1/50th of a second where your subconscious fills in information... Movies, in general, are about entertainment and imagination and escape, the suspension of disbelief... Typically, I don't want to reproduce what you see natively with your eyes, crystal clear images with no flicker... While my position is rarely if ever that the medium is the message, the medium is a key tool...
Handheld work would certainly not be impossible, more improbable or impractical.Kubrick managed it (himself) on 2001
