Howard_S
- Nov 1, 2001
Does video switching offer any increase in performance? Say if you have a VCR connected to a receiver through composite and the receiver to the TV using S-Video would you see a difference?
"Does video switching offer any increase in performance? Say if you have a VCR connected to a receiver through composite and the receiver to the TV using S-Video would you see a difference"
For the connection you are describing (composite in = S-video out), the receiver would have to be cable of "transcoding" or converting the signals to the output format. This isn't possible in most a/v recievers. Video switching is offered mostly for convience of adding more inputs and letting the receiver switch the proper video source along with the audio input with one command. Some say the video switching circuitry in some receivers can actuallly degrade the signal a tad bit, but I've never seen any noticeable difference using any receiver I've owned. On the other hand, video switching can not increase the quality of the signal.
Note: there are a few receivers (I believe Harman/Kardon makes some) that do convert signals. However, this is beneficial only for convenience, as it still will not improve the signal quality over just connecting the component directly to the TV set.
Hope this helps...DB
