Brett DiMichele
- Sep 30, 2001
- Brett
Hey All,
It has come time to do some upgrading and my focus is for
both movies and music I want to do both equaly as well as
the other.
My problem is that my TX-DS787's 100wpc does not power my
AR9 mains very well. Complex Passages that are heavy on the
lows tend to send the Receiver into Thermal OverLoad Protection.
If you compare the AR9 to the AR5 the sole difference is
that the AR5 contains one 175 Watt Mono Carver Sunfire TDC
Amp in each speaker cabinent who's sole duty is to drive
that 10" Bass Reflex Subwoofer.
I didn't want a "powered sub" because there is far more
flexibility with non powered for setup purposes. So I find
myself wanting to Bi-Amplify my 9's.
I have been pondering how I want to go about doing this. In
one respect I could go for straight out 2Channel and buy 4
moderate MonoBlock amps like the nOrh LeAmps or I could go
with a more Home Theater biased 5 Channel Amp which could
be setup for 2Channel and Home Theater.
So what I am thinking is could I do this... I want the
Parasound HC2205-AT which delivers 220 Watts Per Channel
by 5 Channels. I was thinking that I could use this in two
diffrent and unique setups. On the one hand I can run all
of the seperate channel outputs of the 787 into the ParaSound
and that would hook me up with plenty of power for Home Theater.
And then I could also use Left/Right Front and Left Right
Rear Surround's all linked together to the Left/Right Front
outputs of the 787 so that I could send 440 Watts to each
AR9, 220 Watts for the Sub and 220 Watts for the Mids/Highs
in a Bi-Amplify config.
Both ways the volume and everything would be controlled via
the 787 wich saves me from having to buy a seperate Tuner
and PreAmp for 2Ch. I will use the 787 as the source switcher
and Tuner but I am sure I could hook this all up to be switchable
for 2Ch or Multichannel.
Of course I would have to use splitters so that I could plug
all these outputs into the Parasound.
Am I crazy ? Or is what I am concieving founded in logic?
Any suggestions?
My ears are open.
the other.
Any suggestions?
My ears are open.
