Mark Booth
- Aug 25, 1999
Wow, I'm surprised that there wasn't already a topic going on this subject...
I just discovered that, on August 1, 2006, Universal Remote Control made a signficant change in their software policy for their PC-programmable remote controls. That announcement is detailed here:
http://www.remotecentral.com/wn060801.htm
In a nutshell, URC has created two "versions" of their programming software. One version has Live Updates turned off, the other version has Live Updates turned on. If you did not get your remote from an authorized dealer (and there are hundreds, if not thousands of us that didn't), then you only get access to the version with Live Updates turned off. This means that the IR code database you have access to is only the one that was up-to-date as of July 31, 2006 or thereabouts. Any future changes to the code database are unavailable to you.
Fair enough, I guess, for those that purchased their remotes AFTER the policy change. But here's the rub..... URC also turned off Live Updates for those of us that got our remotes BEFORE the policy change. The version of software that was freely available to ANYONE before July 31, and which fully supported Live Updates, has been crippled with no more Live Updates.
I am completely stunned that a company could effect such a policy that would so signficantly alter the performance of an already purchased product in a RETROACTIVE fashion.
Anyway, be warned.
Mark
Anyway, be warned.
Mark
