Gary Shipley
- May 28, 2002
OK, I done quite a bit of research and I'm really torn as to which receiver to get. I do like the Onkyo TX-SR806, however, I'm concerned with the heat issue. I do have my current receiver in a rack. There is at least 2 inches above the receiver and the back is open. I can increase the head room as much as is needed , as the shelves are adjustable. Theres that. My current is 110 wpc. I have also been looking at the Pioneer VSX-03TXH. It too is 110 wpc. I have been satisfied with the fact that the 110 wpc seems to be enough to drive my speakers and fills the room very well , volume wise. So, I guess my question would be, do I really need to go to the 130 wpc Onkyo? Will I notice that much difference between these two recievers?
