Troy Swope
- Mar 1, 2002
I was just asked by a co-worker how to hook a dvd player to a tv, that only has the 75 ohm coaxial cable input. Currently they have it hooked up via a vcr, and then have vcr hooked to the tv. Most DVD's are unwatchable in this configuration (due to copy protection i would imagine).
My question is this, if i purchased an RF Modulator for them, that would accept the composite inputs, and then routed it out via 75 ohm coaxial cable, would we see the same effect as using the vcr mentioned above?
Just thought i could throw this out there to all of you home theater junkies in case someone had run into this before. (BTW, my advice was to purchase a new tv with composite inputs.)
Thanks for the help! This place is awesome!
