ThomasL
- Mar 13, 2001
I was finally able to track down a copy of the service manual for the 20AF41 Toshiba tv. I suspect the service menu is the same for the 24AF41 and perhaps the new flat tubes also have a similar set up. Using the manual, I was able to determine what some of the variables do: GDRV, BDRV are for the high end of the grayscale, GBIAS, RBIAS, and BBIAS affect the low end. There are 4 geometry adjustments: PARABOLA,TRAPEZIUM, CORNER TOP, and CORNER BOTTOM. THere are also the usual horizontal and vertical size and positioning variables.
In addition to the above, I was able to determine that the set was 3 different adjustment "modes" - one for each type of input. If you bring up the adjustment menu while using the Component Inputs, you're in CS mode. If you're using the RF input, it's TV mode and any of the other composite/Svideo inputs and you're in AV mode. Most of the variables are identical in all 3 modes which means they're most likely global settings. But, there are a few that are different and I'd love to know if anyone knows what exactly they do:
UNICOLOR
SUBCONT
TINT is also different but I'm assuming TINT simply sets the same thing as the user level setting - i.e. it sets a baseline from which the user level setting then makes tweaks to. But the other two listed above I am not sure about but they're somehow related to color I would assume? Does anyone have any clues for me?
thanks,
--tom
UNICOLOR
SUBCONT
thanks,
--tom
