Chris Rein
- Apr 18, 2000
Hello!
RAF, I know you have this series of M&K Speakers, but I'm not sure what you did for the center channel.
As some or all of you may know, M&K has an angled center channel for rear projection televisions, as well as, the "normal" one that matches the L & R speakers.
Now, I have a large rear projection television, so sure, the angled center should be the choice I make, correct? Here's the kicker, I'm planning on getting a front projector sometime soon. I obviously won't have the need for the angled center, right? Or can the angled center be positioned behind the screen (or under) to still create the seamless front soundstage? Should I just get the "normal" center channel and just prop it up to angle at the listener?
Thanks for your help. I am pretty much clueless right now!
Chris
Chris
