Greg*go
- Jun 14, 2002
Firefox - Rediscover the Web
Firefox 1.04 Release Notes
Firefox Help
Direct Download Page (for Windows, all builds are further down) or you can use one of the many official Mozilla Mirrors that span the globe.
Themes
Official Extension List | Unofficial Extension List | The official extensions site currently has 289 extensions listed. The unofficial list has 620+, so use the unofficial site if you want a better list.
Firefox 1.0 is out! Since Firefox has been out for over a week now, their site has returned to normal, so you can download it either at the main site, or you can go directly into the Firefox1.0 directory via the Direct Download linked above. They also have torrent files up on that page as well.
On another note, if you are interested in upgrading to 1.0 from an earlier version, and you have extensions, you'll need to update since it looks like they aren't usable in this 1.0 version. You'll have to check one of the lists provided above to see if the makers of the extensions have made versions compatible with 1.0 and then download them. Again, I suggest using the unofficial list.
NOTE: When installing, it is recommended that you back up your old profile. To get access to your profile in WinXP, go into the C:/Documents and Settings/User Name/Application Data/Mozilla. I haven't experienced any problems like I did when upgrading earlier versions, but I backed it up just in case.
Have fun.
Edit: The Mozilla folks have just released a newer version with a set of security patches (including a fix for the IDN issue that made the news). Any browsers built/released before February 24th are in danger. To find out when your browswer was built, go to The Help:About part of Firefox. This new version is entitled Firefox 1.0.1. It has patched 10+ security flaws found in the browser since the 1.0 release in November. If you want the official list of fixes, go to this site. An unofficial list can be found here: squarefree.com
Edit: Firefox 1.0.2 has been released. Any version of Firefox that is dated before Martch 17th should update to this new version. To paraphrase the Firefox 1.0.2 Release Notes:
Firefox 1.0.2 is a security and stability update that is part of our ongoing program to provide a safe Internet experience for our customers. We recommend that all users upgrade to this latest version. Here's what's new in Firefox 1.0.2: Several security fixes, better drag and drop capabilites (both within the browser and to and from other applications), lock icon state fixed when navigating to named anchors in secure pages & bookmarked pages in the sidebar.
The unofficial changelog can be found at squarefree
It should also be noted that only installer builds of Firefox are being issued for this (and all future?) release. Since some people have accidentally downloaded the zip files and caused a world of problems for themselves, the Mozilla team has decided to stop producing zips for the releases.
(Apr 16) Edit: Firefox 1.0.3 is now officially out. This time, they have not only done several security fixes, (including this memory exposure leak) they have also updated the installer. You no longer need to delete the old Firefox before updating anymore. When you install Firefox 1.0.3, simply download the file, then install it. If this is what you have been doing all along, then this install file should get rid of the Firefox 1.0, 1.0.1, & 1.0.2 in your Add/Remove programs settings.
(May 12) Edit: Firefox 1.0.4 is now available for download. This is a security update, with the most important patch being a fix in the "Code execution via javascript: IconURL." The official vulnerablities can be found here. It also fixed a regression in the 1.0.3 realease with DHTML errors occuring while viewing certain websites. Please download this newest version to keep your browser updated with the latest & greatest security.
(Jul 12) Edit: Firefox 1.0.5 is now available for download. This is another security update, also containing some stability updates as well.
Firefox Help
Themes
Have fun.
