Kris Coffin
- Jun 19, 2002
Hi All,
After all the reading I have done, and current watching of LOTR, I have decided I need a better sub setup. 2 Def Tech BP2000tl's with power 15" just don't cut it:frowning: But my question is this, which SVS should I go with, I have definatly decided it will be a 16-46, possibly 2, but which is better? And why? The CS+ can use external amplification, so this is appealing in the long run as I would like to add another Rotel RB-1090 in the future, but, does the CS+ sound just as good as the PC+ with built in amplification?
Thanx much
Kris
Thanx much
Kris
I looked up redundant in the dictionary, uhh, it said see redundant?
