John-Tompkins
- Jan 21, 2003
SOLD...................SOLD................
I have a pair of SVS 20-39 CS+ subs in excellant condition..I would like to sell as a pair and will ship if I have to..but if your somewhere around Northern Va. then local pickup would be great !..These subs are about 2~ 2 1/2 years old and they have the newer 3 port design and drivers..
PAIR OF SUBS for 500.00 PLUS SHIPPING IF REQUIRED
I also have a crown pro amp XLS-402 that drives the heck out of the svs's.. I will throw in the amp and sell the enitre combo for
PAIR OF SUBS ALONG WITH CROWN XLS402 for 650.00
I accept and prefer paypal ..
I have 135 positive feedbacks on audiogon under psujohny and 135 on ebay under the same name.
The XLS 402 power amplifier is a solid-state two-channel model. The XLS402 provides extensive protection and diagnostic capabilities, including output current limiting, DC protection, circuit breaker, and special thermal protection for the unit’s transformers.
The front-panel controls are two black detented level controls (one for each channel), a power switch, and a circuit breaker for overload protection. Front-mounted indicators are Clip: one red LED per channel which illuminates when the channel’s output signal is being overdriven, Power: one green LED which indicates that the amplifier has been turned on and AC power is available, and Fault: one yellow LED which illuminates when amplifier is in protect mode and briefly during normal power-up when amplifier is first switched on.
The recommended load impedance is 2 to 8 ohms per channel in Stereo, and 8 ohms in Bridge Mono. The amplifier is also safe when driving any kind of load, including highly reactive ones.
The rear-mounted output connectors are two four-pole Speakon® connectors and a pair of 5-way binding posts per channel. Rear-mounted input connectors shall be 3-pin balanced XLR connectors.
*1 kHz
XLS 402 Power
2-ohm Stereo (per channel) 570W
4-ohm Stereo (per channel) 400W
8-ohm Stereo (per channel) 260W
8-ohm Bridge-Mono 800W
4-ohm Bridge-Mono 1,140W
*1 kHz Power: refers to maximum average power in watts
at 1 kHz with 0.5% THD
*1 kHz
XLS 402 Power
