veggiop
Grip
- Feb 21, 2011
- veggiop
For my final year project I propose to use the Blu-ray laser unit from a disk drive (something like a KEM-410ACA, without all the problems of using a sony part) to measure surface roughness. I will relate the proportional analog signal from the voice coil motor that focuses the laser dot on the surface of a disk to the a profile of the micro peaks and valleys on the surface. Or possibly the focus error signal. . I will need a stand alone power up sequence for the product and will have to control the motor and get the laser into auto focusing mode. Do you have any suggestions on a unit I can buy that I will be able to get some non-standard technical support with. Also I will need to have easy access to full schematics including pinout configurations.
