Stryke 1501 any good? (1 Viewer)
AlexKunec
Has anyone had any good or bad experiences with the Stryke 1501?
Im kinda leaning towards it instead of the adire tempest because of the price and sensitivity. And also because it is made by Lambda Acoustics.
John E Janowitz
Hi Alex,
The woofer is actually not available yet. It is made by Eminence, the same as the Tempest, not by Lambda Acoustics. Nick did influence the design though. It was originally a woofer that Lambda was goign to Eminence make for them. I'm not sure when they will be avaliable. I just don't have the money for the inventory purchase right now. If there was enough interest and I could presell 25 of them then I could make it happen. Most likely though I will be getting only the SAE1502. It has the best balance in parameters and will work for sealed or vented enclosures.
JoeyT66
