eyeage30
- Jul 5, 2011
- Eric
Important question: If I used a non-CL rated speaker wire (because I wasn't really doing in wall), then decided to run it up through a wall to connect to a speaker.... Could I cover it with something for that 4 ft of going through the wall, do I really need to worry about it, or do I have to go buy CL rated wire and rerun everything (or buy raceways instead of in-wall for that part)? In this 4ft in wall I do cross and electrical line. I'm guessing I'm overthinking it, but it's a new house, would sure hate to have it burn down... [ATTACHMENT=130]1310094728921.jpg (7k. jpg file)[/ATTACHMENT] In addition to this question I have another. On the other side I plan on doing the other surround, with that run I have a box on one side of the 2x4 and the speaker wire on the other. So, I'd be parallel for 2ft at a distance of 2-3 inches... then I'd cross it at 90 degrees. I'm guessing for this one I should insulate it with something just for the interference issue? I may be overthinking this stuff... but I'd rather overthink as compared to underthink
