David Taylor
- Jun 30, 1997
I am posting this for a friend. His firewall at work is blocking access to this forum for some reason.
I have just purchased a Sony PFM-42B2 Plasma TV. The TV has 2 VGA inputs and NO component inputs. It has a picture resolution of 1024 x 1024. It was designed mostly for commercial use and not really for home theater use. I am going to use it in my home theater however.
A link to the spec sheet can be found at:
http://www.francisav.com/images/sony...fm_series2.pdf
My questions are as follows:
- Can i get a true HDTV signal since i do not have component inputs? If so, how?
- Sony makes a component video input adapter (analog component input) that can be purchased for the TV. Would this give a HDTV picture?
- What options should i explore in order to get the best picture i can out of this unit?
- How can I get a progressive scan signal from my DVD player?
- Ideas? Thoughts?
I appreciate your time,
Greg Lunday
- Ideas? Thoughts?
Greg Lunday
